Cristianita
 Using Quotes (") In The Topic Title, It Shows This Signs (") In The Quick Reply.
even in the browser tab:
But not in "POST REPLY" I mean normal reply...
Why?
#1 Fri 11 May, 2018 07:38 |
Informpro
 Re: Using Quotes (") In The Topic Title, It Shows This Signs (") In The Quick Reply.
Hi;
It is done to avoid HTML injection, but this one case needs to be smarter -- we need to differentiate between a value that could be from an attacker or from a trusted source.
#2 Sat 12 May, 2018 21:50 |
Cristianita
Hi;
I'm not sure if I understood you. I think you are saying you need to check this feature, aren't you?
#3 Sat 12 May, 2018 22:07 |
Informpro
Yes, I am saying we are trying to be safe, but we are too safe because of this.
#4 Sat 19 May, 2018 15:34 |
Cristianita
So it's better if we don't use this quotes in the titles, isn't it? Is that what you mean?
#5 Sat 19 May, 2018 22:47 |
I will fix the issue in Quick Reply, but I won't fix it on page title, since injections may be possible.
I'm sure I added all these fixes because of security reasons in the past.
#6 Tue 05 Jun, 2018 00:12 |
Cristianita
I got it... Thanks for all, Mighty Gorgon
#7 Tue 05 Jun, 2018 01:00 |
Cristianita
Hi, God bless you, guys!
#8 Sat 18 Aug, 2018 19:04 |
Similar Topics
Similar Topics
