Post Quick Links Editing
Hey guys, I hooked up phpBB XS to my site the other day and played around in the ACP for some time, until I eventually concluded that I have to go inside TPL files to add and remove what I want from the quick links.
Could you tell me where and what I need to do? I'm guessing its something in nav_quick_links.tpl
thanks
dranemSend private message
Post Re: Quick Links Editing
the file is that , you have to remove or add the link you want, is very simply
sonoangeloSend private messageVisit poster's website
dranem wrote: [View Post]
thanks
Yes, in nav_quick_links.tpl you can find many tables, should be easy for you to find and modify as your pleasure
You could find very useful the MG switch :
  1. <!-- BEGIN mg_switch_user_is_admin -->
  2.
  3.
  4. <!-- END mg_switch_user_is_admin -->
  5.
