Post [SOLVED] Trouble To Show Links And Signatures After Having Changed Server
I changed server a few days ago, everything was going well at the beginning, except for the fact that the CMOD permits of the folders and files were changed, which is something I think I have already sorted out.
The problem now is that some posts are showing broken links from some users (not from all), being showed as follows:
h**p://xxx.xx
You may see an example at the following post: http://www.aranjuez.ws/asamblea-gen...f1-vt18900.html  however, if you look at it from the portal, the link appears correctly:  www.aranjuez.ws
The other issue is that for some reason the signatures of some users (not all) are not shown.
Support data:
www.aranjuez.ws
Version ICY 2.0 without MOD
Non-free server
PausoSend private message
Post Re: Trouble To Show Links And Signatures After Having Changed Server
Pauso wrote: [View Post]
h**p://xxx.xx
Support data:
www.aranjuez.ws
Non-free server
i m not sure if i understand your problem
but YOU enabled spAm protection in ACP
so new users when post link and they have les then 3 or 5 post they links automaticly change to h**p
you can disable this in ACP
Hello!
only see that in cracker tracker, is there?
Limun means ACP >> Config >> Posting And Messages >> Anti-Spam (bottom page)
Note: this contains BOTH problems/fixes
many thanks, that was
