Post Help Request: Signature In Previous Posts, Video Size, Posts Like
Hey guys
Ok I have now done a fresh install of Icy2   though have a few questions/problems and hoping someone can help with. I have gone through search function but no joy.
1st We seem to have a problem with the Check here to attach your signature to your previous posts as well In the user CP  It's just not doing it even though a tick has been placed in the box and then hit submit got to see if its worked and nothing go back to settings and tick has gone ?
2nd Question, is there anyway to resize a youtube video that is posted?
3rd Question, should we be seeing anything/anywhere when someone clicks the like button on a post? (I have it turned on in each forum and in ACP)
Thanks for any help, feel free to yell at me if I have done this wrong
Dragon36Send private message
Post Re: A Little Help Please :)
1. It's normal  that that "tick" will disapear after submit, however it should attach a new or update the old sig to posts posted before the sig-change
2. What exactly do you mean ..do you want to have a bigger youtube screen in the posts or do you want users to have a button for full size viewing?
3. It should change to You like this post • Unlike • Share, it's facebook related
1. It's normal  that that "tick" will disapear after submit, however it should attach a new or update the old sig to posts posted before the sig-change. Hmmm thats not happening but not to worry
2. What exactly do you mean ..do you want to have a bigger youtube screen in the posts or do you want users to have a button for full size viewing? On the older version of icy the video's posted were smaller like a square and now they are bigger like rectangle I was wondering if I could make them like that again
3. It should change to You like this post • Unlike • Share, it's facebook related. Hmmm thats not doing anything at all
Sorry if I'm not making sense   And thanks for such a speedy reply Joshua
Well point 1 and 3 ... for me both seem to work, so it may be best to make some separate topics about these.
About point 2:
I think you should really make sure you know why it was changed before changing it back.
But in includes/bbcode.php this is the old code:
                $default_width = ((($tag === 'youtube') || ($tag === 'googlevideo')) ? '425' : '320');
                $width = (isset($item['params']['width']) ? intval($item['params']['width']) : $default_width);
                $width = ((($width > 10) && ($width < 641)) ? $width : $default_width);
                $default_width = ((($tag === 'youtube') || ($tag === 'googlevideo')) ? '350' : '240');
                $height = (isset($item['params']['height']) ? intval($item['params']['height']) : $default_height);
                $height = ((($height > 10) && ($height < 481)) ? $height : $default_height);
and this should be the new:
                // 4/3 YouTube width and height: 425x350
                // 16/9 YouTube width and height: 640x385
                $default_width = ((($tag === 'vimeo') || ($tag === 'youtube') || ($tag === 'googlevideo')) ? 640 : 320);
                $default_height = ((($tag === 'vimeo') || ($tag === 'youtube') || ($tag === 'googlevideo')) ? 385 : 240);
I would trust MG's edits rather than blindly change it back
Ok will check out the code for the video's and make another post about the like feature (maybe I need to be signed into facebook for it to work)
Can't thank you enough Joshua for your help
PS Now I'm on Icy2 I will try and use the custom bbcode for my text   so get ready for another post LOL
Thanks again m8
Sorry but this time I'm in doubt about the codes i posted earlier, this next part should be more important
old:
                elseif ($tag === 'youtube')
                    $color_append = '';
                    if ($color_1 || $color_1)
                        $color_append .= ($color_1 ? ('&color1=0x' . str_replace('#', '', $color_1)) : '');
                        $color_append .= ($color_2 ? ('&color2=0x' . str_replace('#', '', $color_2)) : '');
                    $width = in_array($width, $width_array) ? $width : '425';
                    $height = in_array($height, $height_array) ? $height : '350';
new:
                    $color_append = '';
                    if ($color_1 || $color_2)
                    $width = in_array($width, $width_array) ? $width : 640;
                    $height = in_array($height, $height_array) ? $height : 385;
Off Topic
Well I have no Facebook account either but the text changes anyway (that doesn't mean it also works on facebook though)
Got it    I deleted the // 16/9 YouTube width and height: 640x385 and changed all the video's to 425x350 and its worked a treat
Thanks Joshua (again)
// 16/9 YouTube width and height: 640x385  is just an info line (it's commented out (//)
i 'ld start by only changing
But like I said you should really make sure if this is smart to do!
You're welcome anyway
Will keep an eye on it but so far so good
Post Re: [SOLVED] A Little Help Please :)
Dragon36
May i ask you, to put explicit Post titles, and not " A little help Please".
Something like " Profile problem" or similar
Because it´s a bit confusing the way you post.
Before one views the post, where´s no way to know, what it is about
I agree Spydie, you could n't have known that I already requested this in PM
Sorry guys note taken
About Video size it's quite tricky... I tried to list some common size to avoid unwanted stretching... you should pay attention when playing with non-standard size.
Topic title edited.
