Post Black_pearl/template//portal/portal_body
hi all im in need of some help i uninstalled the 2 styles that come with phpbb3 as i want all my users to use the same style
the style im useing is black_pearl    Version: 1.4.6
this is the error im getting i no theres no  portal folder so there is no files for it to load and from
all so theres 2 // from template to portal.html
General Error
black_pearl/template//portal/portal_body.html does not exist or is empty
any help be great ty
o i forgot you say i have the i have the portal mod installed
ok i fixed this i forgot to get the b3p black pearl from the portals forums
h**p://***.board3.de/viewtopic.php?f=38&t=1923
theshortySend private message
Post Re: Black_pearl/template//portal/portal_body
Thanks for letting us know you solved your problem.
