Post Donation (Spenden) MOD with PayPal IPN
Hi there,
some month ago i have started to addapt this MOD to phpBBXS.
i ant to share this with you, when the new release is out, but next week i have to leave my home for work and so i´m not on my PC, so i´ll share it now.
  1. ##############################################################
  2. ## MOD Title: Donation MOD phpBBXS
  3. ##
  4. ## MOD Author: sandodo < zouxiong@loewen.com.sg > (Xiong Zou) http://bbs.loewen.com.sg & http://forum.loewen.com.sg
  5. ##
  6. ## MOD Addon Developer/author: KugeLSichA < kugelsicha@caromonline.de > (HoLLe) http://www.caromguild.de
  7. ##
  8. ## MOD Description: Admin can set PayPal accounts to receive donations,
  9. ##                  Donors can choose to be anonymous when donation,
  10. ##                  Admin can set how many points to give to donor when donation, (Must have points MOD installed, otherwise, set it to 0 )
  11. ##                  Admin can also set how many posts count to give to donor when donation,
  12. ##                  Admin can set current donation goal, description and duration,
  13. ##                  Admin can set to display top donors or last donors,
  14. ##                  Admin can manually inset donation information
  15. ##                  Admin can set which group the donor can join after donation, currently support different two groups
  16. ##                  Admin can set which special rank the donor will be set to after donation, anonymous donor will not be set for this special rank
  17. ##                  Supports multi-currencies.
  18. ##
  19. ##                  NOTE: I set up the user rank No.5 ("user_rank5") for the donors Special rank!
  20. ##
  21. ##                  Only the First Admin (user_id = 2) can set up and change the PayPal email adress in ACP!
  22. ##
  23. ## MOD Version: 1.0.3
  24. ##
  25. ## MOD DEMO: http://www.caromguild.de
  26. ##
  27. ## MOD Requirements: phpBBXS Version 058 or higher
  28. ##
  29. ## Installation Level: Easy
  30. ## Installation Time: 10
  31. ## Files To Edit: 13
  32. ##                adm/index.php
  33. ##                forum.php
  34. ##                includes/constants.php
  35. ##                includes/functions.php
  36. ##                includes/functions_dbmtnc.php
  37. ##                includes/page_header.php
  38. ##                language/lang_english/lang_admin.php
  39. ##                language/lang_english/lang_main.php
  40. ##                language/lang_german/lang_admin.php
  41. ##                language/lang_german/lang_main.php
  42. ##                templates/ca_aphrodite/index_body.tpl
  43. ##                templates/ca_aphrodite/overall_header.tpl
  44. ##                viewonline.php
  45. ## Included Files:  22
  46. ##                  donors.php
  47. ##                  donateconfirm.php
  48. ##                  donateresult.php
  49. ##                  donate.php
  50. ##                  donateshowresult.php
  51. ##
  52. ##                  templates/ca_aphrodite/donors_body.tpl
  53. ##                  templates/ca_aphrodite/donate_body.tpl
  54. ##                  templates/ca_aphrodite/donate_topupconfirm_body.tpl
  55. ##
  56. ##                  adm/admin_donors.php
  57. ##                  adm/admin_donate_currency.php
  58. ##                  adm/admin_donate_settings.php
  59. ##
  60. ##                  templates/ca_aphrodite/admin/donors_config_body.tpl
  61. ##                  templates/ca_aphrodite/admin/donate_currency_config_body.tpl
  62. ##                  templates/ca_aphrodite/admin/donate_settings_config_body.tpl
  63. ##
  64. ##                  language/lang_english/lang_admin_donate.php
  65. ##                  language/lang_english/email/html/thanku_donation.tpl
  66. ##                  language/lang_english/email/txt/thanku_donation.tpl
  67. ##                  language/lang_german/lang_admin_donate.php
  68. ##                  language/lang_german/email/html/thanku_donation.tpl
  69. ##                  language/lang_german/email/txt/thanku_donation.tpl
  70. ##
  71. ##                  images/PayPal_mark_37x23.gif
  72. ##                  install/db_update.php
  73. ##############################################################
  74. ##############################################################
  75. ## Author Notes:
  76. ##
  77. ## Terms of Use
  78. ##
  79. ## All of my MODifications are to use and edit/change for phpBB End Users
  80. ## Plese DO NOT remove any copyright/licence declaration when using the MODification
  81. ## I will remain as the sole developer for all my MODifications unless stated otherwise
  82. ##
  83. ## Distribution Terms
  84. ## All of my MODifications are prohibited to distribute to others without the permission
  85. ## from me.
  86. ## Plese DO NOT remove any copyright/licence declaration when using the MODification
  87. ## I will remain as the sole developer for all my MODifications unless stated otherwise
  88. ##
  89. ## Re-Distribution Terms
  90. ## If you are distributing WHOLE or PART of my MOD in your MOD Projects or Pre-modded
  91. ## Projects or any other means, you must: Get the formal authorization from me first.
  92. ## Plese DO NOT remove any copyright/licence declaration when using the MODification
  93. ## I will remain as the sole developer for all my MODification unless stated otherwise. Do
  94. ## NOT declare youself as my co-developer
  95. ## Re-Distribution Terms DOES NOT apply to MOD authors that developing Add-Ons to my MOD.
  96. ##
  97. ##############################################################
  98. ## MOD History:
  99. ##
  100. ##   2004-09-20  -  Version 1.0.1
  101. ##      - init version
  102. ##
  103. ##   2004-10-15  -  Version 1.0.2
  104. ##      - second release: admin manual insert donation record; devide donor to different groups; mark donor as donor;
  105. ##
  106. ##   2006-08-09  -  Version 1.0.2 XS
  107. ##      - some changes/code cleanup to get this running with the phpBBXS Version 058 or higher
  108. ##
  109. ##   2006-09-23  -  Version 1.0.3 XS
  110. ##      - created new page admin_donate_settings.php
  111. ##      - created thanku_donation.tpl so that the donor can recieve an Thank You Email
  112. ##      - Only first Admin (with userid 2) can set up the PayPal email adress in ACP
  113. ##      - view donors at donate.php page bottom
  114. ##      - added PAGE_DONATE session, so that Admin can see if a user is viewing the donate pages
  115. ##      - some TPL and PHP cleanup
  116. ##    - changed, deleted and added all lang VARS (phpBB conform)
  117. ##    - merged the two admin_lang pages into one
  118. ##    - added different "Donate" language images, set by userlanguage
  119. ##
  120. ##
  121. ##############################################################
  122. ## Before Adding This MOD To Your Forum, You Should Back Up All Files Related To This MOD
  123. ##############################################################
  124.
Full credit goes to the first MOD Author Xiong Zou. And also thx to him that he gives me the right to share this with you, because its not under the GPL. You can also visit his forum for other new cool staff.
The Donation MOD can be download in my testforum    http://www.caromguild.de/downloads.php?cat=3   no register is required.
it would be great if you can help me to find bugs, and report them here, but lease not that im away for a week after today evening.
Also if i have some free time i need to do some code cleanup, but the MOD should work now.
enjoy and have fun.
greets
Play Games at GamesCampus!
Post Re: Donation (Spenden) MOD With PayPal IPN
can't download without registration
*VOLVO CLUB*
Post Re: Donation (Spenden) MOD with PayPal IPN
opps.. sry.
Fixed!
We dont want to insert only a simple Donate button here, we also want to explains, why we would be pleased about (every small) donation from you.
I like it    It's professional.
NikolaSend private messageVisit poster's website
Nikola wrote: [View Post]
thx.. the explain texts are from me... maybe not so good translated into english...
thanks
it is nice to see download mod
*VOLVO CLUB*
Great! Thanks.
Megabass
ganeshSend private messageVisit poster's website
difus wrote: [View Post]
thanks
ok now im back and i will start clean up the code and provide it as an XS MOD in the near future
please apply this patch.
donors.php
#-----[ FIND ]------------------------------------------
    $template->assign_vars(array(
        'PAGINATION' => generate_pagination("acctrecords.$phpEx?topicdays=$topic_days&userid=$user_id&mode=$donormode", $topics_count, $topicsperpage, $start),
#-----[ REPLACE WITH ]------------------------------------------
        'PAGINATION' => generate_pagination("donors.$phpEx?topicdays=$topic_days&userid=$user_id&mode=$donormode", $topics_count, $topicsperpage, $start),
Download package updated
first Post updated
Hello,
my english is very bad.
Can you include this mode as standard in the next version?
columbo1979Send private message
columbo1979 wrote: [View Post]
Hello,
I think it won't be included in the package... it will probably remain an addon.
Italian, Spanish, Catala and Serbian translations?
Cosenza United::FCC
My Problem Child
fracsSend private messageSend e-mail to userVisit poster's website
after IP is no BETA Status i release this as Add On on my site....
I have done some changes to this version.
cheers
This modification is only for php XS and maybe is not working with IcyPhoenix.
If you are the author or are able to make them icy compatible, please feel free to post it.
Thanks for your time and the good work so far.
Post new topic  This topic is locked: you cannot edit posts or make replies.  Page 1 of 2
