Post Cash In Post Details
I have installed and have setup the cash and its seen on the profile but I cannot seem to get it to work for post details yet its been set up to work like that. Here is the link I used:
http://www.icyphoenix.com/viewtopic...&p=21478#p21478
Edited by Chaotic, Fri 19 Dec, 2008 15:16: Made topic specific.
rockoSend private message
Post Re: Having Great Differculty
Hello Rocko,
Please edit your topic title to better reflect the problem you are having.  When a user that is having the same problem as you uses our search feature, they'll easily find the questions and solutions that pertain to their issue.
I'm assuming you have enabled the Cash MOD by following the instructions provided in that topic and are wanting to display the Cash details in a user's post details.
Have you entered ACP -> Cash Mod -> Cash Settings and ticked Yes for Show earnings in Post Profile?
It looks like in the viewtopic_body.tpl file, the {postrow.CASH} line will currently only work if you enter ACP -> Configuration -> Icy Phoenix -> Posting And Messages and tick Yes for Show poster's Info on Topics (Lang, Style, etc.).
If you are wanting to display the amount of Cash or Points a user has in the area under their avatar without having to show a user's language, member number, or style, try:
Open:  ip_root/templates/mg_themes/viewtopic_body.tpl
Find and remove:
            {postrow.CASH}<br />
Find:
            {postrow.POSTER_FROM}<br />
After, ADD:
