Re: Few Questions About IP Features
struja,
It's best to create separate topics when seeking help for two different questions. If another user has the same type of problems you are having, they can easily use the search function and find the answers they are looking for. It also helps to make your topic more specific.
You should edit your topic title to reflect only the first question as I'm only going to answer #1 in this post. Create a new topic for your second question, please.
If you created your Quick Titles correctly, you'll notice a new drop down menu under your MOVE, LOCK, SPLIT, MERGE, ANNOUNCEMENT, IMPORTANT, etc. buttons on the bottom right of each topic page. Select the title you wish to prefix your topic title and click Title Edit.
