Post LANGUAGE - Change Ltr To Rtl
hi
i had translate icyphoenix to my language ! and now i need to change ltr to rtl !
how can i change this direction ?
what is name of files to i must edit ?
please help !
thanks
FunkySend private message
Post Re: Change Ltr To Rtl
Open:
lang_main_settings.php
Find:
$lang['DIRECTION'] = 'ltr';
Thanks for translating it - Is it going to be available here. ?
Thank you, I know about lang_main_settings.php
I mean changing the direction of styles
I hope so, but we have a problem with the Forum Style
After changing direction &_^
Hi Funky, I'm not sure what problem you are actually having -
And this doesn't look all that hopeful -> h**p://***.icyphoenix.com/viewtopic...&p=28237#p28237
Obviously these themes have been translated, maybe it's helpful if you can approach these people and ask them to share. ->
h**p://***.sadad-center.com/sadad/index.php
The attached file is RTL for MG_Styles, and contains style_ice - common - dock and FAP.css
Maybe that's some help.
Edit:
File deleted and added to RTL.zip further down the Thread.
Thanks, moved to Docs.
Thank you my problems have been solved  but left only a few problems
 such as Arabic registration problems
but i well ask sadad-center about this problem
Thanks again for the attached file  helped me  a lot
You're welcome.
And as an exercise on how difficult it is to convert to RTL, I modified the "Lopalong's Modified Shoutbox" to RTL if you would like to either use it or test it.
Edit:
File removed and Upgraded Shoutbox added to RTL.zip further down the thread.
Hi All
This Is The File You Need For RTL  IP
(functions_validate )File Will Solved The Registration Problems You Can Get It From Her (sadad-center).
To The World You May Be One Person ,But To one Person You May Be The World
awillSend private messageSend e-mail to userVisit poster's website
Hi awill,
Thanks a lot for the RTL template set for Icy Phoenix.
Edit:
I've had a look at these themes and they appear to have partially edited tables and patched images, rather than have a consistent table structure and config that uses the default image-sets. So basically they are a one-off, while the "ice" style appears to have not been modified. So it's a mixture of patched tables, config and images that would make it a little difficult to be able to add "other" Icy Phoenix styles to without a great deal of work.
But thanks again anyway, - Even if I'm not sure if it is going to be all that useful.
awill wrote: [View Post]
Hi All
thanks for sharing but style problem was solved by lopalong just download this file Ice RTL.zip
and about functions_validate has solved  Registration Problems
in Attachment
I will update my tobic after I complete  the translation
functions_validate.zip
Filename: functions_validate.zip
Filesize: 2.07 KB
Downloaded: 501 Time(s)
Hi Funky,
I've edited my post above yours as to why the themes from awill may not be suitable anyway. But as I'm not Arabic, I can't be 100% sure on the usefulness of them to be able to add other Icy Phoenix Themes to, without a great deal of work .
If you want to, or need some help to move things around in the default mg_themes template set. - PM me.
Edit:
Aw what the heck - I felt like doing something different today and came up with this.
Both the shoutbox and all the .css files have been upgraded, as the ones that I "found" previously, were slightly over-worked.
Anyway, if you use the files in the .zip - You should get roughly what's in the snapshot, as other modifications were made or "cleaned up" after that pic was put together.
This image wont create a thumbnail - Click Here
RTL.zip
Filename: RTL.zip
Filesize: 23.2 KB
Downloaded: 539 Time(s)
Hi Funky,
okay thanks you are the expert here no problem
Yes, I want buttons site in PSD if you would not mind u can send it to me in PM
wow very cool lopalong
you can see your work in Arabic forum and simple problem
From here screenshot
Mmmm,
That pic tells me that someone else is hard at work too.
I think I'd better leave it up to you to organise the compiling of templates and just yell out if you need specific help with something.
I don't have Paint Shop, and the buttons in the .zip are the default (As they come) blank ones in .gif.
Re moving the Mini Icons: Can you let me have a copy of the index_box.tpl that is in that snapshot, thanks. ?
And we may as well keep it all in this thread too, for two reasons. One is that someone else may have something to offer, and two - once the translation and conversions are finished, this thread will become redundant.
Cheers!
empty_buttons.zip
Filename: empty_buttons.zip
Filesize: 11.91 KB
Downloaded: 478 Time(s)
