Re: Site Updated To Dev Version
I don't wanna be a kick in the ass, but after upgrade, IP support it's tooooooooooooooooooooooooooooooo slow for me. And my internet is not too bad, other sites still opening fast, but I noted this about two days, so so....
Just for your knowledge...
Sorry...
I think there were some problems in the server... can you confirm the site is still slow? I can navigate it quite fast.
Very nice but don't like font on the icons. The whole template is clean, clear, neath but font not strong or firm.
Do you mean this?
when I view a group I see the select heading
Thanks for reporting, I'll try to create a switch for that.
lopalong =
MG's right hand ?!
Lopalong is doing great and helping very much in the Debug and Development process. Of course he is supporting as well.
Thank you very much Lopalong, you are saving me a lot of time. I really appreciate.
Only one hint... Kaspersky is blocking all the banners (Sponsors) maybe there is a way to fix it.
I don't know how many users are using Kaspersky and I don't know how Anti-Banner works.
Mmm... so the banner are not appearing?
If it is just a matter of banner not appearing, then I won't matter... I'm even thinking to remove them, because I'm not earning much from them... less than 10$ per month...
Dammit!
All the image downloads in the forums are corrupt and return encrypted code, and the .zip's are now useless
Every MOD (With Files) I've posted have had to be re-directed, because I can't successfully replace it with an updated version.
Can you point me to some posts with this error?
If it is confirmed it is a major issue and has to be solved
ASAP.
I will make same tests.
Thanks for reporting.
