We have recently changed our Portal block to the one that comes with the FAP 1.4.1 DL.
Works fine, apart from that it only shows Albums which have the "all" view permission enabled.
Is there a way to set it so that the block will show whatever pictures the user has permissions to view?
Also wondering the same about the other block that is attached in the 1.4.1 DL:
## MOD Title: Full Album Pack Pictures Blocks
## MOD Author: Mighty Gorgon <
> (Luca Libralato) http://www.mightygorgon.com/
## MOD Description: This MOD adds a block of recent, random, most viewed, or most rated pictures, anywhere on your phpBB.
## MOD Version: 1.0.0
Can it use permisisons in the same vay on any page in the forum?
Thanx for reply,
Just a short note to say I am working on it. When I followed the instructions, the block dsapperaded from the portal..
but I am sure I am doing something wrong....
Working on it, and appreciate your reply!
best
jtm
The time now is Sun 22 Dec, 2024 07:12 • All times are UTC + 1 Hour
