Post Warning
hello I have a lot of Warnings please can someone tell me what to do.
My site www.zebravinken-gouldamadinesite.nl
Warning: fopen(./cache/sql_ct_config_472022be091812506f0b3d47818afb38.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_config_3ba19af46892e3453550c70fc489cba0.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_attach_f82dfb867587d92cbdb4646606bf0262.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_posts_9c0c21b2de78c2e51da0211afa310144.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_posts_5642ae56192b39d53ce013f746b752dd.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_auth_e1d0c7941bd30b966742ab639b7f0a83.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_cms_0662cc1c8f18a5da7ed28fbcfaf8b1aa.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: ob_start(): output handler 'ob_gzhandler' conflicts with 'zlib output compression' in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/page_tail.php on line 178 Warning: fopen(./cache/sql_smileys_784b71bb0cadef59f3f19d91c54af091.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662
Warning: fopen(./cache/sql_cms_bc61e49f2cda020c849c6a31e0ca67dc.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_cms_3dca0c5b25e8c102516e9b498e5dd766.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_xs_config_0d6b909122f5a0787d5237b74c030567.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_xs_news_f4f8dc1b738b22bccbc2806baa097c75.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_xs_news_xml_3453a43275f9f94d2f6e2d00de846119.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_auth_e1d0c7941bd30b966742ab639b7f0a83.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_word_censor_873ef28c3a7aa39e72987036b59b613c.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/sql_album_config_117504209a9e39dab4701ebf5433cb37.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: fopen(./cache/birthday_0.00.dat): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/blocks/blocks_imp_calendar.php on line 102 Warning: fwrite(): supplied argument is not a valid stream resource in /usr/local/pem/vhosts/105603/webspace/httpdocs/blocks/blocks_imp_calendar.php on line 103 Warning: fclose(): supplied argument is not a valid stream resource in /usr/local/pem/vhosts/105603/webspace/httpdocs/blocks/blocks_imp_calendar.php on line 104 Warning: fopen(./cache/sql_auth_86f3ea790d3e56fed876f55d1dc8aab8.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662
MrCrazySend private message
Post Re: Warning
oke I have the most of the warnings gone
but I have 1 left I think and the problem that My forum is off for wordk but in my ACP its online
Warning: fopen(./cache/sql_posts_5642ae56192b39d53ce013f746b752dd.php): failed to open stream: Permission denied in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/db/mysql4.php on line 662 Warning: ob_start(): output handler 'ob_gzhandler' conflicts with 'zlib output compression' in /usr/local/pem/vhosts/105603/webspace/httpdocs/includes/page_tail.php on line 178
Post Re: Warning
disable gzip, clean cache and try again
Post Re: Warning
try re-setting the chmod permissions.
Post Re: Warning
hmm
I tried everything I think I wil begin al over a gain
Post Re: Warning
You don't need to restart... follow this hint!
