Post Remove Quick Links
Is there any way to totally remove (or at least hide by default) Quick Links from the forum?
Also, can I have News and Calendar hidden for all users by default?
vasilisSend private message
Post Re: Remove Quick Links
If you close them... then they stay closed.
For Calendar go to Configuration--->Page Permissions---> Set to admin
Megabass
ganeshSend private messageVisit poster's website
That's what I mean... I dont want users to close them, I want it closed by default
Any solution plz?
I've removed that calender and news.. somewhere
eh.. overall_header.tpl I believe
that in templates/aphrodite somewhere
check out my site sometime
www.Dutch-HQ.net
NizzleSend private messageVisit poster's website
Have you asked your users if they use the Quick Links?  I personally think it's great and one of the main reasons I use phpBBXS.
No site anymore
ClaireSend private message
hi , i need this help too
i want hide the quick links on forum.php as default
carltesSend private message
You have to modify nav_quick_links.tpl the JS which reads the cookie.
Try on your own, If you cannot solve this I'll try to help you then.
well , need your help
not understand after browse nav_quick_links.tpl
open index_body.tpl and viewforum_body.tpl
find and cut
<!-- INCLUDE nav_box.tpl -->
now you have to correct some tables
*VOLVO CLUB*
difus wrote: [View Post]
find and cut
that is remove quick link ?
but i want to hide quick link as default at forum.php , not remove it
mighty gordon said it on nav_quick_links.tpl the JS which reads the cookie.
but i not sure how to do it
You should have this somewhere:
<script language="javascript" type="text/javascript">
tmp = 'quick_links';
if(GetCookie(tmp) == '2')
    ShowHide('quick_links','quick_links2','quick_links');
</script>
You can change it in this way:
if(GetCookie(tmp) == '1')
</script>
i've remove (commented) this lines
  1. ##<!-- INCLUDE nav_box.tpl -->
  2. ##{CALENDAR_BOX}
  3. ##{BOARD_INDEX}
  4.
but the box doesn't go away
i 've also deleted nav_box.tlp but it doesn't resolve my problem
lordalbertSend private message
yeah how do u completely remove the quick links from the forum index but not from portal.?????
fidundergroundSend private message
fidunderground wrote: [View Post]
Do you have XS or Icy Phoenix?
I have IP. How can i delete quick links block?
Gianni PBSend private messageVisit poster's website
Post new topic  This topic is locked: you cannot edit posts or make replies.  Page 1 of 2
