Post Limit For HTML-Code In A New Block ?
i create a new block via cms and insert the html-code (exceltable save as html) in. when i now open the new site in a browser, the table is not showing complete. the end is missing. I test it with central-block, columns 2 and 3. Everytime the same result. when i look at the code-box for the block in cms the code is cut. Everytime i test it it`s the same: i can store the new block but when i "look back" the code is cut. In the db under ip_cms_blocks - "filename" is only the code without the end.
i`m testing icyphoenix at home with xampp. can this be a problem?
can somebody tell me whats going wrong?
storyteller
(sorry for my old german-school-english   )
StorytellerSend private message
Post Re: Limit For HTML-Code In A New Block ?
Can you try to post here that code please?
For the kind of code you are trying to include, I guess it is better to convert it in standard HTML instead of using MS Excel HTML output.
If you have Dreamweaver you may find it useful to convert that code.
