Re: How To Add New Link Fileds In Header?
Open overall_header.tpl from your template folder (mostly templates/mg_themes/)
- <tr>
- <td align="left" width="8"><img src="templates/fk_fx/images/fx/menu_sep.png" alt="" title="" /></td>
- <td class="genmed" align="left"><a href="faq.php">FAQ</a></td>
- </tr>
AFTER ADD
- <tr>
- </tr>
And you have two FAQ links, so you can edit one and you have a new link in your top navigation bar.
NOTE: The find lines are not exactly what your find in overall_header.tpl, i have copy it from your website source!
But i think that you know how it can with my answer!
Good luck and let my now if it is so far!
