Post Hello! One Question About Images In Add Custom Fields...
Hello!
I have a question, or how I can do it if one can or not.
I would like that in the option Add Custom Fields ... I can put on images, for example like in the image that I attach. I configure the options of the imge in the profile (that the images could be chosen) and already.
It is possible to do it forming it?
Thank you very much
* THE IMAGE IS A PHOTOSHOP
Filename: Untitledas-1.jpg
Filesize: 95.97 KB
Downloaded: 664 Time(s)
carlosSend private message
Post Re: Hello! One Question About Images In Add Custom Fields...
Mmm... at the moment I guess it is possible by customizing lang_profile_fields.php and inserting the HTML code for the image.
Example:
  • Create a custom field with radio buttons. Call it TEST for example.
  • Add the options with these demo name: TEST1, TEST2, TEST3.
  • Open lang_profile_fields.php and create these vars:
    $lang['1_TEST'] = 'Test Field';
    $lang['1_Description'] = 'Test Description';
    $lang['2_TEST1'] = '<img src="images/logo_ip.png" alt="" border="0" />';
    $lang['2_TEST2'] = '<img src="images/logo_ip.png" alt="" border="0" />';
    $lang['2_TEST3'] = '<img src="images/logo_ip.png" alt="" border="0" />';
Of course you should customize images and fields to suit your needs.
Can you make some tests and then report to me?
Example:
Hello!
Ok, I test now, It runs in phpBB XS??
Hello!
I have tested, I only see the text (TEST1...)
Check the in DB the ID of the fields you have created and update the number in front of the lang var.
Hello!
Sorry but I don´t understand
One thing, I have edit the lang_profile_fields.php and I have put the code in the file. But in DB nothing
Post here the content of your phpbb_profile_fields table.
Ok, Is this ?:
Filename: Untitlased-2.gif
Filesize: 48.42 KB
Downloaded: 614 Time(s)
No, I need the content of that table... but I need it in a text file... can you export it please?
Hello! I don´t know what is, so I put some things
table       type       possible_keys       key       key_len       ref       rows       Extra
phpbb_profile_fields     system     NULL     NULL     NULL     NULL     0     const row not found
Wait, because I have one problem
No... I need the table contents...
