Post [SOLVED] Avatar Panel Failing (Should Be Something...?)
One question: should be something inside this code:
    elseif ( $mode == 'editprofile' || $mode == 'register' )
        if ( !$userdata['session_logged_in'] && $mode == 'editprofile' )
            redirect(append_sid(LOGIN_MG . "?redirect=profile".$phpEx."&mode=editprofile", true));
            //redirect(append_sid(LOGIN_MG . "?redirect=profile.$phpEx&mode=editprofile&cpl_mode=reg_info", true));
        include($phpbb_root_path . 'includes/usercp_register.'.$phpEx);
        exit;
Thanks in advance, because this makes my avatar panel fail.
JacKThERiPPeRSend private message
Post Re: Avatar Panel Failing (Should Be Something...?)
Please tell us a little more about your error
Well, whenever I enter the avatar control panel, it doesn't show anything below the header. That's it.
SOLVED: Added to .htaccess the line "php_value memory_limit 16M".
