Post Problem With Home Page Table
Hi all,
my IP version is: 1.3.0.53
template: white Pearl
link: http://www.fmaitalia.netsons.org/forum
I'm making the new template for my forum but i have a problem
at the moment in the Home Page the left menù does not "touch" the footer if the news table is too tall
what I want to know is if exist a command that extend the left menù and his background
to the same length of the news table and join it whit the footer?
sorry for my orrible english
MarfoSend private message
Post Re: Problem With Home Page Table
Your English isn't bad at all.
I'm moving this topic to the styles and templates forum for you.
Chaotic wrote: [View Post]
Thank you^^
Hi all,
I've solved my problem only in part because with, Firefox, Chrome and safari now the left menù join with the footer
but using IE 8 in compatibility mode as you can see there is a "little" problem!
http://fmaitalia.netsons.org/forum/
Now what i've done is that:
1-created new directory called layout in templates root
2-edited 2_coloumns.tpl
here the code:
<style type="text/css">
#container{
background: url('http://www.fmaitalia.net/templates/fmai/images/skin/ms_bg.png') left;
height: 100%;
width: 250px;
</style>
  <!-- BEGIN nav_blocks_row -->
  {nav_blocks_row.CMS_BLOCK}
  <!-- END nav_blocks_row -->
  <div id="container">
  <table cellspacing="0" cellpadding="0" border="0">
      <td style="vertical-align: top;"><!-- BEGIN left_blocks_row -->
        {left_blocks_row.CMS_BLOCK}
          <!-- END left_blocks_row --></td>
      <td style="padding-left: 0px; vertical-align: top;"><!-- BEGIN center_blocks_row -->
        {center_blocks_row.CMS_BLOCK}
          <!-- END center_blocks_row -->
          <!-- BEGIN xsnews_blocks_row -->
        {xsnews_blocks_row.OUTPUT}
        <!-- END xsnews_blocks_row -->
          <!-- BEGIN centerbottom_blocks_row -->
        {centerbottom_blocks_row.CMS_BLOCK}
        <!-- END centerbottom_blocks_row -->
      </td>
  </table>
this part of code:
#container{
height: 100%;
width: 250px;
</style>
is here only for test if it works after I'll put that in the stylesheet
can you help me to solve the problem whit IE please?
Edit: Sorry for the double post my error, i've pushed Quote and not edit
Sorry, but I don't understand what you need to achieve.
By the way... nice personalization of Icy Phoenix... keep up the good work.
HaoAsakura as solved the problem and I forget to advise You i'm sorry.
The template as you can see is made by Hao and not by me i'm only helping him because after i'll install that on My Forum
at the moment it isn't nothing particoular
www.fmaitalia.net
after I'll post what has done Hao to solve it^^
Thank you very much for reporting us that your issue is solved.
Here I am ^_^
I don't know whether the solution is the correct ... I added this property
"float: left"
Now the left column, with IE7, remains fixed
http://img407.imageshack.us/img407/...nnerbakabk0.png
HaoAsakuraSend private messageVisit poster's website
You did a great work with your forum, i like a lot how it looks.
Good luck!
krisstewartSend private message
