How I Make My Own Template?
Subject: How I Make My Own Template?
I wonder if there are more templates or how can I make my own
Well I know it should be hard but i hope someone can answer me
I try to find a template about games or ONLY BLACK but i cant fine a good one :(
thanks
Subject: Re: How I Make My Own Template?
did you saw a black pearl ?
http://www.icyphoenix.com/dload.php?action=file&file_id=60
and did u saw all templates in this section
Inactive User
And what it the overall theme of the template set. ?
Undertakers Association ?
Men in Black ?
Or is it specific to something that you want to try to emulate ?
Or do you have a concept that is not any of the above ? :mricy:
Yes I saw those ones but the problem is the lines are too lights so make it confuse.. i want everything black and the line a little dark so people can see ITs a line, :(
lvliguel wrote: [View Post]
well i suggest you to install black pearl and affter that show us what "lines" you mean ...
Inactive User
FK Themes "Warcraft" is all black with a hint of borders etc. You could use that as a base to start with, and change the images and .css to exactly what you want.
Obviously you have an idea of what you would like to end up with, and I suspect that you know of some forums that have themes you would like to emulate. A snapshot would answer a thousand questions if you can provide one.
Black pearl could be a great start, and do not forget around Icy phoenix Colorize It! ;)
OK!!! I like the Black pearl
for start, and I put a flash in the Wellcome :) wow I am getting addicted to icyphoenix :s
anyway now I am making my own HEAD but my head show in the LEFT.. and how can I change it to the Center or play with it?????
and how can I change things like icons o pictures
thanks
....I am making my own HEAD but my head show in the LEFT.. and how can I change it to the Center or play with it?????
HEAD you mean header?
if yes :?:
open your overall_header_bl.tpl
change here
<td height="150" align="left" valign="middle"><a href="{FULL_SITE_PATH}{U_PORTAL}" title="{L_HOME}"><img src="{FULL_SITE_PATH}{SITELOGO}" alt="{L_HOME}" title="{L_HOME}"/></a></td>
align="left" change to align="center"
oh men thanks I was looking for that!!!
one more question
how can I delete the WORD MOST USED??
and I wanna have like here... NEW FEW TOPICS and uhmmmm i think that is it :s
one more question
WORD MOST USED?? i dont understand ... can you be more specific please
in the footr it shows me the words which are more uses
sorry for my english
but it says something like
ACP (1) admin (1) album (1) asdsadsasaddasd (1) backup (1) bienvenido (2) blocks (1) category (1) charset (1) choosing (1) cms (1) configure (1) control (1) create (1) define (1) delete (1) download (1) error (1) everything (1) forums (1) free (1) htaccess (1) icy (2) installed (1) keywords (1) lalalala (1) langmainsettings (1) languages (1) main (1) may (1) menu (1) options (1) pages (1) panel (1) periodically (1) permissions (1) phoenix (2) preferences (1) read (1) refer (1) regarding (1) remember (1) reporting (1) rewrite (1) sasdas (1) section (1) settings (1) since (1) styles (1) successfully (1) support (1) tune (1) visit (1) welcome (2) while (1) whole (1) work (1) you (1)
aha tags !!
CMS > 3 Columns > Wordgraph
disable Wordgraph
tags_1220504299_612790
and for recent topics....
CMS > 3 Collums > Add block
recent01
recent02
recent03
Generation Time: 0.7259s (PHP: 4% SQL: 96%)
