Re: Icy Phoenix 2.2 Beta 1
I don't need to read through anything other than what happens from this point in time because I have the latest from GIT and it's got errors in the album plugin. what's more I don't want to spend a lot of time so lets start somewhere here..
First I've patched the block file with the right path.
Next:
Ignore my previous post...
Plugins/Photo Album/Configuration
Template->make_filename(): Error - template file not found: ../common/
ACP/album_config_settings_body.tpl
Open:
plugins/album/adm/templates/admin_album_config_settings_body.tpl
Find:
'template_file' => ADM_TPL . 'album_config_settings_body.tpl'
Replace with:
'template_file' => ALBUM_ADM_TPL_PATH . 'album_config_settings_body.tpl'
These are all of the affected files where no doubt most of the ADM_TPL will have to be changed to ALBUM_ADM_TPL_PATH
BUT! some of them may need to be not changed as they could be using "common" file that exist in the root/
ACP/*.* though I doubt it and it's too risky just to change them willy-nilly! (although I'm thinking about it!)
'template_file' => ADM_TPL . 'album_config_upload_body.tpl'
ADM_TPL . 'album_cat_body_debug.tpl', BUT ONLY FOR DEBUGGING PURPOSE, and send me a screenshot of it
then go back to this template file ADM_TPL . 'album_cat_body.tpl'.
'template_file' => ADM_TPL . 'album_config_clearcache_body.tpl'
// for alittle hint see the template file ADM_TPL . 'album_config_sub_body.tpl'
'template_file' => ADM_TPL . 'album_config_gd_info_body.tpl'
'template_file' => ADM_TPL . 'album_config_index_body.tpl'
'template_file' => ADM_TPL . 'album_config_personal_body.tpl'
'template_file' => ADM_TPL . 'album_config_thumb_body.tpl'
EDIT:
Ok, I swung the axe at this and changed the lot otherwise one cannot navigate the Album settings in the
ACP.
Go To:
And check every file for:
ADM_TPL .
And replace it with:
If you do them all the same time with something like
Notepad++ don't leave the dots off the ends else you will end up with a mess..
