Post [Solved] URL Rewrite Broken :S
I have modified the hotlink protection of my server, but finally I have put it off.
I had also rewrite on and well working, but after the change of the hotlink protection to off with URL Rewrite the forum don't work, it says "The page is not found in this server or the link is malformed"
I have deactivate the URL rewrite in order to the people can use it.
Any ideas?
Thanks!
My 2 IP Forums:
Post Re: URL Rewrite Broken :S
it is because your host has it deactivated
Desing
KtmDesingz
[spoiler][img]http://i116.photobucket.com/albums/o37/_ktm_/Firma32.jpg[/img][/spoiler]
-ktm-Send private messageVisit poster's website
Check if mod rewrite is activated on your host
I have worked with it for 1 month until 10 hours ago  :S ... I will try now to upload .htaccess.
Edit: Done, .htaccess error. Don't know why hotlink protection delete all lines without # of the .htaccess.
Thanks to all .
PD: The rewrite mod is usefull for normal users?? or just for bots?? How to deactivate it for normal users if so?? Or just I don't care?
My 2 IP Forums:
Dont let me delete it, look
My 2 IP Forums:
Post Re: [Solved] URL Rewrite Broken :S
http://www.icyphoenix.com/viewtopic.php?t=411
Thanks but I have done that 2 moths ago
It makes forum go faster also.
My 2 IP Forums:
yes i've made it too
