Post [Solved]Problem On Transfer Whole Forum To Under New Domain
I have installed new XS 0.58b (And it worked correctly)
I upload all database from the other forum (XS 0.58).
I change from phpMyAdmin all things have changed (server name, email, etc...)
And if you put the new URL ( http://forov360.com ) you get:
Warning: mysql_error(): supplied argument is not a valid MySQL-Link resource in /home/forov360/public_html/db/mysql4.php on line 626
Warning: mysql_errno(): supplied argument is not a valid MySQL-Link resource in /home/forov360/public_html/db/mysql4.php on line 627
Critical Error
Could not connect to the database
Any idea?
Thanks!
My 2 IP Forums:
Post Re: Problem On Transfer Whole Forum To Under New Domain (Me
hmmm , i transfer before but not face on this problem
i transfer all file to new directory , and then update phpbb_config table
carltesSend private message
wrong data in config for sql connection
*VOLVO CLUB*
then it should be edit config.php
But it worked before... :S
I have installed it again, I will upload table by table...
My 2 IP Forums:
but maybe your new hosting works on another mysql version
maybe 3.0
Zuker, how to do to solve it if that is the problem?
Now I'm uploading table by table and seeing if there is a table that the forum don't like.
My 2 IP Forums:
ask your server what kind of mysql version uses...
tiolalu wrote: [View Post]
it is not right
you are not connected !first you must connect to sql
bad user or password or both
server - localhost
use same as connecting through phpmyadmin
*VOLVO CLUB*
Now its online because I reinstalled it.
I have remplaced from all posts, the older URL to the new URL, and uploading again, but I have the same problem as this morning (execution time exeeded 300 seconds) and it don't upload .
My 2 IP Forums:
post one test post
*VOLVO CLUB*
I have upload forums table, but I don't see them. If I enter to the ACP and go to Admin forum -> "Permisos" they are, I can see all of them.
What ca I do to see all of them in forum page?
Thanks!
My 2 IP Forums:
syncrhonize forums? did u try it?
Thanks!
do you post one test post ?
do it and see what happens
*VOLVO CLUB*
The news are online in the portal now.
If I try to post in the unique forum there are, it tells me: Lo sentimos, pero sólo pueden publicar temas en este foro. = We are sorry but you can only post in this forum :S.
Sorry for asking so much, but I'm little bit desperate, Database is very huge, and I have to do it all by hand   .
My 2 IP Forums:
Post new topic  This topic is locked: you cannot edit posts or make replies.  Page 1 of 2
