Page 1 of 3
Goto page 1, 2, 3  Next
Post Bug In Album?
WhyI see only a part of images when I open a thumbnail?
http://www.umbriaforum.com/album.php
Post Re: Bug In Album?
really strange... i dont have this error
Play Games at GamesCampus!
I am thinking it is server problem
or time or size limit
how is working your download?[not upload]
*VOLVO CLUB*
andrea75 wrote: [View Post]
Yes, I think that the problem is on your side... if I remember well, you used to have problems even with LIW, and all GD related functions...
If you try opening the mid_thumb, the image is opened correctly, so the image isn't corrupted:
http://www.umbriaforum.com/album_picm.php?pic_id=577
I think you should ask your provider to fix GD problems definitely.
Now I haven't got any problem with GD or LIW... only the albun doesn't work..... now I'll try to disable GD.
your OTF gallery is working.
but why your pictures are opening in new window?
and after refresh is showing picture location
*VOLVO CLUB*
difus wrote: [View Post]
I don't know! Nothing works in album..... all file seems to be ok...
sorry ,but it is funny
never seen that
try to upload a bigger picture in OTF.we'll test it
try to change some settings in ACP>album
*VOLVO CLUB*
never seen that
OTF? What is this?
Trust me... your host have limited in some way the getimagesize function... maybe it's a problem of memory limit.
Try to insert this at the beginning of your album_common.php
ini_set("memory_limit","16M");
In OTF gallery there are only small pictures, that could be the reason...
andrea75, try to upload via FTP some big images into album_mod/uploads/otf/demo/ then try to launch album_otf.php.
Nothing change with this, and in OTF all works fine....
But I see a really strange thing... If I call images from post with [albumimg] tag all works fine
http://www.umbriaforum.com/viewtopic.php?p=21042#21042
The same image, but called from album doesn't showm correcly!   It's impossible!
interesting thing
when I save the image ,it is all image
try to replace  album_showpage.php in root
*VOLVO CLUB*
more
now I can see your watermark
can you temporary change it to default
or switch off it
*VOLVO CLUB*
interesting thing
Album_shopage is ok... and watermark is off now
one is working, second -no
after  refresh - all OK.oh yes it is cache.clear cache
 images is opening in same window  now
when did it happened ? after update to 058
but full images are not opening
*VOLVO CLUB*
Post new topic  This topic is locked: you cannot edit posts or make replies.  Page 1 of 3
