Blank Paged After Update To 2.0
Subject: Blank Paged After Update To 2.0
Hello,
I just found some other error in my board after Upgrade to 2.0
The following menu links result in blank pages:
Album
Personal Pics
Sitemap
Display of user profiles is also not possible.
What could be the problem here?
Subject: Re: Blank Paged After Update To 2.0
I think it would be best to provide a link to your website Rene :wink:
Just as i want to add a new demo user I realize that the links are working now, maybe it was something with caching.
I only have to open issues:
- Sitemap is only displayed as XML, it says no stylesheet is referenced.
screenshot127
- In album page it seems that all images cannot be found. Do I have to change all path? I thought there was a point during the migration procedure, but i didn't know what path I had to replace exactly.
screenshot126
Rene wrote: [View Post]
That is normal for a sitemap ;)
Please check the upgrade instructions and make sure you followed them exactly, especially point 8 in your case.. http://www.icyphoenix.com/docs/readme_english.html#upgrade_ip
Hi, i changed the path during migration.
screenshot130
It seems that the path to the image is not correct in DB.
For example:
PicId 200
img src="album_thumbnail.php?pic_id=200
Entry in IP_album column pic_filename = 2/2/2/IMG_0045.JPG
Path on FTP: /public_html/board/files/album/users/2/IMG_0045.JPG
link please?
Make sure that you did these steps:
upgrade instructions wrote:
17.Run install/database_update.php to update your DB (i.e. http://www.mysite.com/ip/install/database_update.php).
18.Run install/install.php since you need to run Add Uploaded Images To DB (Upgrading from Icy Phoenix 1.3 or above) to add all uploaded images to DB (i.e. http://www.mysite.com/ip/install/install.php).
..and:
Fresh install wrote:
3.Set the permissions to CHMOD 777 to the following files and folders:
◦files/
◦files/album/
◦files/album/cache/
◦files/album/med_cache/
◦files/album/users/
◦files/album/wm_cache/
◦files/images/
◦files/thumbs/
◦files/thumbs/s/
The pfad is wrong:
Should be 2/IMG_0045.JPG
The 2 is the User-ID from the user how upload the pic.
So if you have other users than you, you have check this too.
My fix would be:
  1. Make a backup of your DB or at least for ip_album
  2. run the script for renaming all pfads (see below)
UPDATE ip_album
SET pic_filename = REPLACE(pic_filename, '2/2/2/', '2/')
WHERE pic_filename LIKE '%2/2/2/%'
That should work :mricy:
Generation Time: 0.1473s (PHP: 14% SQL: 86%)
