Hi there,
There is a little typo, misspelled "Nav Benu Bottom" in Ads & Sponsor Menu. I managed to correct it, but i want to know if anyone can help me how to add 3, 4 more ads below Nav Menu Bottom? I appreciate it.
Thank you,
xmenfile.
Nav Menu Bottom Ads
Subject: Re: Nav Menu Bottom Ads
I haven't tried this out yet, but it may or may not work.
There is an ADS block that will allow you to place multiple ADS almost anywhere. After you set the block up, you'll need to edit /your_language/lang_main_ads.php to enter your AD codes.
Again, I don't know if this is what you are looking for or if it solves anything. It's just a small block that gets overlooked sometimes.
Good luck and let us know if this does what you want! 8)
Thank you Chaotic for your respond. I already correct the language and there is ONLY 1 add on Top and Bottom of Nav Menu. What am I trying to do is create more ads below Nav Menu instead of 1.
Can anyone help me how to add a few more ads below menu, please?
Thanks,
Thanks,
It's HTML... you can add more in the same ads item by just adding the HTML code.
xmenfile wrote: [View Post]
Generation Time: 0.4789s (PHP: 4% SQL: 96%)
