Solved-Default Template Problem After Server Reboot
Subject: Solved-Default Template Problem After Server Reboot
Hi everyone!
My host is upgrading/replacing all their servers. I almost lost my site 2 nights ago. Page gen time went past one minute!
After that passed, they re-booted my server. I started having a template problem after the page gen. time went back to normal.
I have all my templates working. The only problem I see right now, is that the default template does set, but I see no users converted to that default template. Also, when I log out, clear cookies, close browser, re-open browser, and log in, then my selected template shows one thing and will never show my actual choice. I and everyone else has to choose their template each time they log in.
I know it's related to my host's server issues, such as php3 and mysql, but I was wondering which files can I check/replace?
My current forum stats: from ACP
forumstats2
And what I am seeing after the server reboot:
templatesettings
thanks in advance
:mrorange:
Inactive User
Subject: Re: Default Template Problem After Server Reboot
Didn't you say in your template blog (Another Thread) that you had "Modified some .php files that users should PM you for the details"?
I suggest that you post those changes here.
Yes. I'll do that.
Basically it's what I did here: http://www.icyphoenix.com/viewtopic.php?f=2&t=4094&highlight=
You helped me sort that one out. I made the changes stated in the above topic.
I have another problem at the moment. Everything was fine, except the above problem.
I was adding another template style and have another error.
I'll have to fix this problem first to get my forum running again.....now starting a topic with that problem.
:chef:
Generation Time: 0.1421s (PHP: 13% SQL: 87%)
