Hello,
When I want to install Icy Phoenix, in the first step before the instalation it checks if I got certain files and it has the right permission to edit them but it says the following map doesn't exist: ../pafiledb/cache/templates/ca_aphrodite
I checked the files I downloaded from the website and even redownloaded it, but this map is indeed missing and without it I cannot install Icy Phoenix!
Please help. :(
-Psorian
[BUG]Missing File Preventing Me From Installing Version .27!
Subject: Re: [BUG]Missing File Preventing Me From Installing Version
Temporary fixed it by downloading the Aphrodite template and uploading it to my server. But still a bug.
ca_aphrodite was "removed" a long time ago - it makes no difference functionally, because the template folder is never used - mg_themes is instead. Most people ignore the message, but yes, it should really be removed from the chmod array to avoid this confusion. ;)
Well it prevented me from continueing the installation earlier today. :? (The button to continue the installation didn't appear.)moreteavicar wrote: [View Post]
It did not stop me before. Anyway, you can create a folder like that in that directory or click on Download on this site, download the style and upload it to directory ../pafiledb/cache/templates/ca_aphroditePsorian wrote: [View Post]
The button is on the bottom of the page... you can continue anyway, there is no condition on the buttons all are shown anyway whether conditions are met or not.
Think it was either cause of the fact I installed it with Firefox or because I had uploaded the Dutch language pack aswell that the button did not show up. :oops:Mighty Gorgon wrote: [View Post]
Generation Time: 0.1369s (PHP: 13% SQL: 87%)
