SOLVED Critical Error
Subject: Critical Error
This came from Nowhere... in a moment the forum was ok, on next sec it wasnt anymore and this msg was shown:
Critical Error
Error doing DB query userdata row fetch
DEBUG MODE
SQL Error : 1016 Can't open file: 'ip_users.MYI' (errno: 145)
SELECT u.* FROM ip_users u, ip_sessions_keys k WHERE u.user_id = 2 AND u.user_active = 1 AND k.user_id = u.user_id AND k.key_id = '466be7aa796c324b0508f106d2174745'
Line : 90
File : sessions.php
I have this forum for about a month and it is hosted on awardspace. Any idea of what this can be and how to fix it, please?
I cant open it since like 20 hours ago
Subject: Re: Critical Error
So... Can anyone help me?
That table is corrupt. Try to repair it using DB tools
or run this sql
REPAIR TABLE ip_users
Zuker wrote: [View Post]
or run this sql
Thankz alot! I fixed it coz of you.
:) title edited to solved
cya
Generation Time: 0.5074s (PHP: 3% SQL: 97%)
