[SUCCESSFULLY SOLVED] Search Box Goes To Different Places
Subject: [SUCCESSFULLY SOLVED] Search Box Goes To Different Places
Hi!
Well, at IExplorer, when I search somthing by the Search Box, it takes me to the found topics.
But now, if I search by Firefox, it takes me to the advanced search page!!!
That didn't happend before, do you know what could have been changed?
Subject: Re: Search Box Goes To Different Places!! Lol
Well works here, but might be your search database table. I heard you can clear it before. Maybe MG or someone will know.
THANKS FOR ANSWER!!
I will try what you said, although I'm not very good at SQL. xd
greetings!
You can do this in ACP - database utils.
Nothing hapened. It still takes me to the advanced search. I optimised database, restored word search lists, etc...
Weird...
Do you have a link for testing this?
Sure, try in here:
http://www.elautillocoloso.com
but remember try it with Firefox.
Hail!!
Edit your search_block.tpl and remove the <a> tags from around the submit button
BTW: Very nice site :up:
You are the Master!! :chef:
Not only solved the trouble, YOU SOLVED 2 TROUBLES. XD
I was about to remove the line under the button, but I couldn't do it. And I never thought it had relationship with the fact that it took me to the Advanced Search. YOU SLOVED TWO PROBLEMS IN ONE xd xd xd
Thanks!!!
Subject: Re: [SUCCESSFULLY SOLVED] Search Box Goes To Different Place
I found it strange that IE didn't react as FF did :?
Anyway, you are welcome ... and there is no charge for the 2nd problem :mryellow:
vote Artie for president :mricy:
hehe thy artie for your great help here on this site 8)
KugeLSichA wrote: [View Post]
Glad to help.
Thanks goes to you too, as we are all members of the same team. :up:
Generation Time: 0.4871s (PHP: 4% SQL: 96%)
