SOLVED Problem With Viewtopic-body.html In Phpbb Gallery And Black Pearl Style
Subject: Problem With Viewtopic-body.html In Phpbb Gallery And Black Pearl Style
Hi there
First, thanks for the great Black Pearl Style :)
I have some trouble with the Gallery Mod for phpbb. There I should find in subsilver2 template in the viewtopic_body.html this line:
<td><div class="gensmall" style="float: {S_CONTENT_FLOW_BEGIN};"> <!-- IF postrow.U_POST_AUTHOR --><a href="{postrow.U_POST_AUTHOR}">{PROFILE_IMG}</a> <!-- ENDIF --> <!-- IF postrow.U_PM --><a href="{postrow.U_PM}">{PM_IMG}</a> <!-- ENDIF --> <!-- IF postrow.U_EMAIL --><a href="{postrow.U_EMAIL}">{EMAIL_IMG}</a> <!-- ENDIF --> </div> <div class="gensmall" style="float: {S_CONTENT_FLOW_END};"><!-- IF not S_IS_BOT --><!-- IF postrow.U_EDIT --><a href="{postrow.U_EDIT}">{EDIT_IMG}</a> <!-- ENDIF --> <!-- IF postrow.U_QUOTE --><a href="{postrow.U_QUOTE}">{QUOTE_IMG}</a> <!-- ENDIF --> <!-- ENDIF --> </div></td>
and in this line I should find
and add after them following code:
<!-- IF postrow.U_GALLERY --><a href="{postrow.U_GALLERY}"><img src="{T_IMAGESET_LANG_PATH}/icon_contact_gallery.gif" alt="{L_PERSONAL_ALBUM}" /></a> <!-- ENDIF -->
Now, the prblem is, that in Black Pearl no such code like above exists. I looked in subsilver2 because BP is bades on this style.
Can somebody tell me what I have to change in Black Pearl indeet the subsilver2 file?
Many thanks
Faethor
Subject: Re: Problem With Viewtopic-body.html In Phpbb Gallery And Black Pearl Style
Hi Faethor, welcome to Icy Phoenix :wink:
I have edited your post to swap Bold bbcode for CODE bbcode, please use this next time you include code samples (it's easier to read and safer to not cause possible conflicts).
I'll be taking a look at your problem now and post back once I see what you are talking about.
You should have absolutely no problem finding this line directly in black pearl (not even a need to compare to subsilver2):
:wink:
Hi Joshua
Many thanks for editing my post and helping me to solve my problem :) I didnt know that I can the code that is around the line to edit :)
Now it works fine but my next problem is, that I need a german button for the gallery.
Do you know where I can find empty buttons in Black Pearl style to create one? If I download the existing ones, ther are to small to edit :(
Thanks!
Faethor
What exactly do you want the button to say?
Gallery or Album ...something else?
http://www.icyphoenix.com/files/images/10637/album.jpg
It should be like this, but in Black Pearl Style :)
Maybe without the camera :)
Look at the bottom of my posts .. right click the album image and download it ... rename it and upload it to the correct directory :wink:
PS.... oooh maybe first you need to switch this site to black pearl style in profile or portal :oops:
Great! That helps a lot!
I uploaded your image, but where I have to change the code that the right button will be displayed?
Sorry for that many questions...
faethor wrote: [View Post]
Don't worry ... that's what we're here for!
It's why I said "rename the downloaded button", if you rename it to what the mod uses (icon_contact_gallery.gif) and while uploading it choose to overwrite the original, it will use the new image :wink:
Ah, this way. I would like to hold the original one, if somebody wants to change to subsilver2 style. I named the button icon_contact_gallery.png. like all my german buttons :)
Is there a chance to do this?
Any style has its own folder for those lang buttons.
So for any style you would need to upload the button of your choice, the style you want to have default image should contain the original button and black pearl the new one.
Just incase .... you need to do the all edits for all styles on your board too.
I uploaded the button to styles/black_pearl/imageset/de
I changed the imgaeset.cfg this way:
[color=#E50000]img_icon_contact_gallery = icon_contact_gallery.png[/color]
But the button is still the original one :(
Have a close look at the added code:
it's going for .gif not .png :LOL:
Just found it :D
Many thanks for your support!! Now it works.
You're welcome ... I'll mark this thread as SOLVED (something you can do by yourself in the future at title edit ...right bottom of the page)
Generation Time: 0.2376s (PHP: 10% SQL: 90%)
SQL queries: 31 - Debug Off - GZIP Enabled
