hi i need help removing 1 and to hide 2 if user is not loged in pls help.
Help With Black Pearl
Subject: Re: Help With Black Pearl
It's not a template problem and has nothing to do with Black Pearl. ? It's permission settings with phpBB3 forum administration.
Your question belongs at the phpBB3 support forums, where you will probably find the answers. ;)
aaa... its in the black pearl's code mate not in phpbb3 (i know what i am talking about because i tested but cant remove it)
il try on phpbb forums to tks any way
Lopalong wrote: [View Post]
So you want to remove the column permanently, and hide the gradient only when someone is not logged in?
Correct? :shock:
Correct? :shock:
The blank column is for topic icons... as subSilver does.
The header I don't know why... can you provide a link?
yea i want to remove it permanently and that heder (2) i want to hide it if user is not loged in not just the gradient the whole column i hope u understand.
here i found a forum that has this modification:
I guess they disabled topic icons...
To phisically remove that column you have to edit viewforum_body.html:
<!-- IF S_TOPIC_ICONS -->
<th colspan="3"> {L_TOPICS} </th>
<!-- ELSE -->
<th colspan="2"> {L_TOPICS} </th>
<!-- ENDIF -->
<th> {L_AUTHOR} </th>
<th> {L_REPLIES} </th>
<th> {L_VIEWS} </th>
<th> {L_LAST_POST} </th>
<!-- BEGIN topicrow -->
<td class="row1" width="25" align="center">{topicrow.TOPIC_FOLDER_IMG}</td>
<td class="row1" width="25" align="center"><!-- IF topicrow.TOPIC_ICON_IMG --><img src="{T_ICONS_PATH}{topicrow.TOPIC_ICON_IMG}" width="{topicrow.TOPIC_ICON_IMG_WIDTH}" height="{topicrow.TOPIC_ICON_IMG_HEIGHT}" alt="" title="" /><!-- ENDIF --></td>
<!-- ENDIF -->
<td class="row1">
<!-- IF topicrow.S_UNREAD_TOPIC --><a href="{topicrow.U_NEWEST_POST}">{NEWEST_POST_IMG}</a><!-- ENDIF -->
{topicrow.ATTACH_ICON_IMG} <!-- IF topicrow.S_HAS_POLL or topicrow.S_TOPIC_MOVED --><b>{topicrow.TOPIC_TYPE}</b> <!-- ENDIF --><a title="{L_POSTED}: {topicrow.FIRST_POST_TIME}" href="{topicrow.U_VIEW_TOPIC}"class="topictitle">{topicrow.TOPIC_TITLE}</a>
<!-- IF topicrow.S_TOPIC_UNAPPROVED or topicrow.S_POSTS_UNAPPROVED -->
<a href="{topicrow.U_MCP_QUEUE}">{UNAPPROVED_IMG}</a>
<!-- ENDIF -->
<!-- IF topicrow.S_TOPIC_REPORTED -->
<a href="{topicrow.U_MCP_REPORT}">{REPORTED_IMG}</a>
<!-- ENDIF -->
<!-- IF topicrow.PAGINATION -->
<p class="gensmall"> [ {GOTO_PAGE_IMG}{L_GOTO_PAGE}: {topicrow.PAGINATION} ] </p>
<!-- ENDIF -->
</td>
<td class="row2" width="130" align="center"><p class="topicauthor">{topicrow.TOPIC_AUTHOR_FULL}</p></td>
<td class="row1" width="50" align="center"><p class="topicdetails">{topicrow.REPLIES}</p></td>
<td class="row2" width="50" align="center"><p class="topicdetails">{topicrow.VIEWS}</p></td>
<td class="row1" width="140" align="center">
<p class="topicdetails" style="white-space: nowrap;">{topicrow.LAST_POST_TIME}</p>
<p class="topicdetails">{topicrow.LAST_POST_AUTHOR_FULL}
<a href="{topicrow.U_LAST_POST}">{LAST_POST_IMG}</a>
</p>
</td>
<!-- BEGINELSE -->
<td class="row1" colspan="7" height="30" align="center" valign="middle"><span class="gen"><!-- IF not S_SORT_DAYS -->{L_NO_TOPICS}<!-- ELSE -->{L_NO_TOPICS_TIME_FRAME}<!-- ENDIF --></span></td>
<!-- ELSE -->
<td class="row1" colspan="6" height="30" align="center" valign="middle"><span class="gen"><!-- IF not S_SORT_DAYS -->{L_NO_TOPICS}<!-- ELSE -->{L_NO_TOPICS_TIME_FRAME}<!-- ENDIF --></span></td>
<!-- ENDIF -->
<!-- END topicrow -->
<tr><td class="cat-bottom" colspan="<!-- IF S_TOPIC_ICONS -->7<!-- ELSE -->6<!-- ENDIF -->"> </td></tr>
<!-- ELSE -->
<!-- ENDIF -->
<!-- ENDIF -->
<td class="row1">
<!-- ENDIF -->
<!-- ENDIF -->
<!-- ENDIF -->
</td>
</p>
</td>
<!-- BEGINELSE -->
<!-- ELSE -->
<!-- ENDIF -->
<td class="row1">
<!-- ENDIF -->
<!-- ENDIF -->
<!-- ENDIF -->
</td>
</p>
</td>
<!-- BEGINELSE -->
<tr><td class="cat-bottom" colspan="6"> </td></tr>
<td class="row1">
<!-- ENDIF -->
<!-- ENDIF -->
<!-- ENDIF -->
</td>
</p>
</td>
<!-- BEGINELSE -->
Generation Time: 0.3518s (PHP: 6% SQL: 94%)
SQL queries: 30 - Debug Off - GZIP Enabled
