1.1.0.15a - Cumulative Patch
Subject: 1.1.0.15a - Cumulative Patch
Cumulative Patch for Icy Phoenix 1.1.0.15
Hi all !
It's the first patch for the gold release. Most of the known bugs are fixed. :wink:
How to install it?
Just download, unpack and upload all included files replacing old ones... no SQL changes required.
If you download the latest IP, you don't have to use Cumulative Patch for IP 1.1.0.15a, download has been updated with the patch.
_____________________
EDITED BY MG
Release number has been changed to 1.1.0.15a.
For a while I'll release only bug fixes, I'll update only this file from time to time, unless a bigger modification is required.
Subject: Re: 1.1.0.15 - Cumulative Patch
Thank you zuker,
in the patch folder there are 3 tpl files for MG themes... do they apply to the aphrodite theme also?
jz wrote: [View Post]
Thank you zuker,
No, you don't need to apply them to Aphrodite.
Grazie :mricy:
Subject: Re: 1.1.0.15a - Cumulative Patch
Patch updated yesterday.
Just download and replace all files and your version is raised to 1.1.0.15a.
Somebody can explain to me that he is this? Please, it is that not, in serious.
Greetings and Thanks!
It's a patch for IP. If u have download the package after the date i post this. You don't have to aply this patch
oh, ok
Thanks! :mryellow:
Is there a cumulative bug fix list somewhere?
check bugs forum
zuker soy colombianflow en phpbb-es.com necesito mods para icy phoenix es que no me deja entrar la pagina mandame los que puedes necesito de bbcode por en mi foro no me sirven si kieres mirarlo entrar a h**p://monteriacity.com.es/ gracias te lo agradesco si me ayudas...... :( :( :( :( :( :(
This it's an english speaking community neo-monteriacity
For spanish support visit phpbb-es (temporally down)
drexful wrote: [View Post]
1.1.0.15a should fix reported bugs until number 5... all the other known bugs are really small and I'll fix them with a bigger update package as soon as I've tested the new groups system a bit more.
Sorry,
I don't update my forum from a lot of time.
I've the version 1.1.0.15.
Can I update directly to "Icy Phoenix 1.1.0.15d or 1.1.7.22a RC1" or i've to do all the update (a,b,c,d,RC1)?
Hip_T wrote: [View Post]
Sorry,
I think you should upload all files from a 1.1.0.15d fresh install without rewriting the config.php file.
Not upload the install folder.
Not sql queries needed.
Generation Time: 0.4155s (PHP: 5% SQL: 95%)
