With a new install on a new server, no pictures or thumbnails are shown, just a red X.
I've used FAP in the past on a different server, without problems. I just installed a new phpBB2 forum on a new server and installed FAP 1.4.0a with easymod, without errors. The upload folders are correctly CHMODded. Uploading of a picture works without errors; the picture can be found in the upload and cache folder and in the database.
When looking at the album however, no thumbnail or picture is visible, just the infamous red X. A direct link to the picture or thumnail does work however, I'm not sure what that means for my problem.
GD 2.0.28 is installed on the server. I've added the domain to the hotlink-prevention, but prevention is currently set to NO, so this shouldn't matter. Clearing the cache folder doesn't help.
On the smartor forum someone mentioned that possibly the readfile() function was disabled. I've checked this with my host and this is not the case. Also, I've removed any php safety features the host installed as a precaution, but still no result. I've read in this forum about .htaccess in the upload folders, but I can't see any .htaccess there.
I've run out of things to check. Anybody have any suggestions?
album visible at Album (1 picture in the public category, 1 in the personal gallery)
Direct links to the Full picture or the Thumbnail
phpinfo: phpinfo
If you would like to test for yourself use login: tester password: tester
