SOLVED How To Add Custom BBCodes?
Subject: How To Add Custom BBCodes?
I was posting a topic in my forum needed to add a table, and noticed that are not those bbcodes :shock:
I've looked around the search, but I didn't find the way to add my custom BBCodes...
This is the page:
5152411826
I added at the first space a BBCode code like this:
[table border="1"][tr][td][/td]
[td][/td]
[/tr]
[tr][td][/td]
[td][/td]
[/tr]
[/table]
And added this code at the second one:
<table border="1">
<td></td>
<td></td>
<td></td>
<td></td>
</table>
When I pick "Send", this is the result
Información
Debe especificar la etiqueta de BBCode
« Volver a Pagina previa
It means:
information
You must specify the BBCode tag
«Back to previous page
I have no idea what is "BBCode Tag" :oops:
Subject: Re: How To Add Custom BBCodes?
The bbcode tag is the "name" of the bbcode, in the brackets, i.e.:
[the name is here]
Informpro wrote: [View Post]
[the name is here]
I'm so sorry :oops: what is "the brackets"? I don't know where should I write this tag :shock:
You cannot add multiple tags like you did...
Anyway TABLES are not part of standard BBCodes for a reason! It's not easy to create cells within tables making sure you close all tables correctly...
Follow the examples on that page... here is another one:
BBCODE: [background={COLOR}]{TEXT}[/background]
HTML: <span style=\"background-color: {COLOR};\">{TEXT}</span>
Well, I know how to make tables using BBCode and HTML also... but I think is not a good idea to allow HTML in my forum, am I right? That's why I want to add this BBCode :roll:
The issue is that, if someone doesn't properly close a table or a cell, the whole forum will look bad... And you can't easily check if they did a table properly or not.
oooh, I got it!
So, the only option is to use HTML, right?
Is not a risk to the forum? Because I have to make tables sometimes...
You can enable HTML only for administrators. Then it's not much of an issue.
Yes, I can do that, and I will... Thanks, Informpro :mryellow:
I used to use a big titles in the beginning or my posts. There are some BBCodes (h1, h2, h3...) that make bigger the titles, and I'd like to know how can I add this BBCode to the forum.
Because they are not dangerous to the forum, right? Not like tables, for example... :roll:
Nope, these aren't dangerous :). You can add those as bbcode, but you can also just change the size?
Is this a question? 8)
If yes... Well, I don't know how can I do that, but I guess you could help me :roll:
Definitely! When you post a full message, you see a bot to select font / size / color right under the subject:
g13g2km
To make text big, here's how you do it:
jpq8vae9yd
Oh, I understood!!
Sorry... Yes, I know how to make the text bigger applying BBCode size and bold, and everything else...
But if I had a BBCode h1, h2, or h3, with different sizes and color, it could be easier and faster to post a message...
Ok, I see what you mean. Do you want them to output actual <h2>, or something with a different size and color?
Generation Time: 0.1232s (PHP: 55% SQL: 45%)
