Page 1 of 4
Cristianita
I Bought A SSL Certificate, And The Images (and YouTube Videos) Stopped Showing Up, Just Appears The Thumbnails
When I forced the SSL Certificate since Hostinger, I changed the setting secure cookie too since the ACP.
Well, despite I bought the SSL Certificate, the grey symbol is still there, and is because some images. Most of the images changed their url http to https automatically, but not all, I don't know why.
For example, this image:
http://elcaminocorrecto.com.mx/images/news/48_icy_phoenix.png
It was not uploaded by me, but by your package. Why this imagen didn't change its URL?
In another hand, some images in my posts don't show up, only the thumbnails; but when I click the thumbnail, the image doesn't show up, nothing happen except "loading"... "loading"... "loading"...
This is one of them:
https://elcaminocorrecto.com.mx/files/images/2/santiago.jpg
and this is the post: https://elcaminocorrecto.com.mx/un-...vp199.html#p199
This image was uploaded to my storage, and has https, secure URL, what is wrong with this?
I have not any idea how can I fix this issue
I've noticed that YouTube videos don't show up either...
Please, help me
Neither the smiles have changed their http URL to https... Why not?
Edited by Cristianita, Tue 01 May, 2018 18:12: Add Information |
#1 Mon 23 Apr, 2018 22:52 |
Informpro
Re: I Bought A SSL Certificate, And The Images Stopped Showing Up, Just Appears The Thumbnails
Quote: Most of the images changed their url http to https automatically, but not all, I don't know why
Did you change the "Server URL" setting in your admin panel?
#2 Wed 25 Apr, 2018 14:20 |
Cristianita
I don't know where is this "Server URL"
Do you mean this area?
There is not any place saying "Server URL"...
#3 Wed 25 Apr, 2018 21:56 |
Cristianita
#4 Fri 27 Apr, 2018 05:29 |
Cristianita
I'd tried to change "elcaminocorrecto.com.mx" to "https://elcaminocorrecto.com.mx", but it was a mess... I almost can not enter my forum anymore because the http doubled.
I need to fix this problem because it is affecting my forum in SEO.
#5 Mon 30 Apr, 2018 05:58 |
Re: I Bought A SSL Certificate, And The Images (and YouTube Videos) Stopped Showing Up, Just Appears The Thumbnails
Hi Cristianita, did you solve your issue?
#6 Fri 04 May, 2018 22:14 |
Cristianita
Not yet, Mighty Gorgon, While you could check it out, I've sent a message to Google support forum. I'm waiting both.
#7 Sat 05 May, 2018 20:34 |
Cristianita
I think I have to repeat this info. Since I've set the SSL Certificate, the lock has an exclamation sign saying "the conexion is not secure". This is because the smiles didn't change their url http to https. How can I fix this issue? Do I have to delete all the smiles, and uploaded them again?
#8 Wed 09 May, 2018 03:15 |
Cristianita
I really need help... The YouTube Videos do not appear yet...
#9 Tue 15 May, 2018 22:07 |
Cristianita
I've already asked in Youtube Help Forum, and Google Help Forum, and both have sended me to this support forum because they say you should know how to help me. The problem is about the CMS, editing some HTML, changing http to https, and maybe changing or editing some YouTube BBCodes.
The green padlock still doesn't appear in some pages of my forum, showing insecure and mixed content yet. The YouTube videos still doesn't show.
God willing you can help me sooner or later... Better sooner rather than later! ¡Shalom!
The problem is that my forum changes the URL of YouTube Videos of https to http. That's why they don't appear. Following the instructions from the YouTube Help Forum, and using the inspector, it showed this:
From this topic, using the inspector:
As you can see, the video space is there, but not the video. The URL is http, not https, that's why the video doesn't appear.
Now, I've added the "s" to http, click enter, and the video showed up.
When the message was posted, using the YouTube BBCode, the Video URL had https. But the forum changed it.
The YouTube Help Forum says that I have to change or edit the CMS of the ACP, about the cookie privacy or something like that.
When I bought the SSL Certificate, I configured this:
I don't know what else I can do... On Hostinger, I found some tutorial saying I have to change the .htaccess file to force the SSL Certificate. But I've rather don't touch this file.
I'm still waiting for your help.
#10 Thu 17 May, 2018 21:24 |
Cristianita, maybe some old link is still in the DB.
You may try to fix it by emptying the "Precompiled Posts" ( ACP -> Clear Cache) and try searching and replacing in DB ( ACP -> Forum -> Replace In Posts):
#11 Thu 17 May, 2018 22:51 |
Cristianita
Hi, Mighty Gorgon
Quote: you may try to fix it by emptying the "Precompiled Posts" ( ACP -> Clear Cache)
Ok, I've already did it many times.
Quote: and try searching and replacing in DB ( ACP -> Forum -> Replace In Posts):
http://elcaminocorrecto.com.mxOPEN [b][/b]
I'm not sure what are you talking about... Where can I find this option? I've found similar option, where I have to create a new word or line, not "find" my forum URL.
#12 Fri 18 May, 2018 02:45 |
Informpro
The "Find" / "Replace With" was meant to be the piece of text to look for, and the piece of text to replace it with, that you have in the "Replace In Posts" feature. Hopefully this is clear, otherwise I will provide a screenshot :).
#13 Sat 19 May, 2018 15:36 |
Cristianita
I think I found this place.
But I'm not sure if this is the solution of the problem.
I did it, I've followed the advice of MG, but the problem still there. The green padlock still doesn't showing up and the YouTube video either. The video URL has http not https.
I'm concerned about this message:
It means "it can not be undone". What does that mean? What relevance does it have?
In the other hand, the link mentioned there is this:
https://elcaminocorrecto.com.mx/algo-para-reflexionar-vf20-vt97.html
But it's not exactly, because through the ACP, the link is this:
https://elcaminocorrecto.com.mx/viewtopic.php?t=97&sid=9789cd58d84735eaf3eebd62e8aa4e4f
But it's the same, the green padlock still doesn't show up.
#14 Sat 19 May, 2018 22:41 |
Cristianita
Nothing yet?
#15 Tue 29 May, 2018 20:59 |
Page 1 of 4
Similar Topics
Similar Topics
