Re: The Images Saved In A Different Place (like Servimg) Shows "NO Thumbnail"
Ah I forgot the Highslide part. Sorry. Im going to go try that real quick and see if it still works for me or not. I need to learn to re read posts before trying to duplicate a issue.
Ok take a look at this:
http://raybrowell.com/IcyClean/viewtopic.php?f=3&t=5
All those are hosted on Imgur. All I see is some letters and no thumbnails, but if I click on them the image shows up in HighSlide.
Now take a look at this:
http://raybrowell.com/IcyClean/viewtopic.php?f=3&t=6
That image is hosted in my album and does not work with highSlide at all. it goes right to my Album image.
http://raybrowell.com/IcyClean/viewtopic.php?f=3&p=10#p10
That image is using the upload image button in the post. Everything works great.
Bottom line is, the only way I was able to get HighSlide to work accordingly was to allow uploading of images in the post which if your website gets busy can fill your hosting package real fast which is bad.
using Imgur, I was able to get highlide to work as you were able to see, but there is no thumbnail generated.
