Where are you getting this error?
Are you sure you uploaded all the file when migrating?
Simply entering the forum, there is something that always goes to that template, I have solved it by installing the squared template. As much as in the ACP put a default template always goes to that. Is there any file where this is defined and can be edited manually? Thanks
The time now is Mon 03 Feb, 2025 06:44 • All times are UTC + 1 Hour
