Can someone please help me identify where i am going wrong ?
I have created a Standard Page in CMS
As you can see i have ticked the Breadcrumbs checkbox and setting are as
how do i get them to appear on my page like this ( albums page )
Also on any page that i have created a standard page for i cannot get the logout button to display the text of logout, but its fine in all other pages, ie album, forum, index etc ( Last button in the clip above and below )
my page start code is as shown
if (!defined('IP_ROOT_PATH')) define('IP_ROOT_PATH', './');
if (!defined('PHP_EXT')) define('PHP_EXT', substr(strrchr(__FILE__, '.'), 1));
include(IP_ROOT_PATH . 'common.' . PHP_EXT);
include(IP_ROOT_PATH . '/ticklists/ticksummaryconfig.'.PHP_EXT);
$sortby = $_REQUEST["REGION_FILTER"];
// Start session management
$user->session_begin();
$auth->acl($user->data);
$user->setup();
// End session management
$cms_page['page_id'] = 'leaderboard';
$cms_page['page_nav'] = (!empty($cms_config_layouts[$cms_page['page_id']]['page_nav']) ? true : false);
$cms_page['global_blocks'] = (!empty($cms_config_layouts[$cms_page['page_id']]['global_blocks']) ? true : false);
$cms_auth_level = (isset($cms_config_layouts[$cms_page['page_id']]['view']) ? $cms_config_layouts[$cms_page['page_id']]['view'] : AUTH_ALL);
check_page_auth($cms_page['page_id'], $cms_auth_level);
Appreciate any help
