Post FAP CUSTOMIZATION - Change 'Show All Comments' Button To 'Show New Comments'
hey,
I'm wondering how I can change the Show all Comments button on the 'All Pics' page to actually show new comments instead of comment count. I realize this is selectable in the dropdown menu, but i feel it's a more important feature and should be easily accessible via the button.
krisbfunkSend private message
Post Re: Change 'Show All Comments' Button To 'Show New Comments'
You can do this, but it will also affect when viewing all pictures of users .... if that matters to you.
ArtieSend private message
Not sure what you mean. So it's not possible without great effort to just change the button path to show 'new comments' instead of 'all comments' without changing the default display of 'all photos' by 'time' on the 'All Pics' page?
It is no problem to simply change the path of the button
OPEN album_allpics.php
'U_SHOW_ALL_COMMENTS' => append_sid(album_append_uid('album_allpics.' . $phpEx . '?'.$album_view_mode_param.'&type=comment')),
'U_SHOW_ALL_COMMENTS' => append_sid(album_append_uid('album_allpics.' . $phpEx . '?'.$album_view_mode_param.'&type=comment&sort_method=new_comment&sort_order=DESC')),
that's great, works perferctly, thanks Artie.
You are most welcome.
i tried to make this work for ratings too....
'U_SHOW_ALL_RATINGS' => append_sid(album_append_uid('album_allpics.' . $phpEx . '?$album_view_mode_param&type=rating&sort_order=ASC')),
i wanna display that pic with the last rate on it at the first position an the page.
but it wont work
maybe you can fix my problem ?
AnemiaSend private message
Anemia wrote: [View Post]
but it wont work
you're missing a couple periods and single quotes in your code..
try this, it worked for me:
  1. 'U_SHOW_ALL_RATINGS' => append_sid(album_append_uid('album_allpics.' . $phpEx . '?'.$album_view_mode_param.'&type=rating&sort_order=ASC')),
I forgot to include this in my post above:
"First you should apply this fix:  http://www.icyphoenix.com/viewtopic.php?t=946 "
Ascending is the default. If you want the order descending try this:
'U_SHOW_ALL_RATINGS' => append_sid(album_append_uid('album_allpics.' . $phpEx . '?'.$album_view_mode_param.'&type=rating&sort_method=rating&sort_order=DESC')),
