Enabling in ACP takes no effect... we have to check..
If you wish the visit counter block on Portal then add this block via the CMS system, which you can reach from forum index, if you have the rights for that.
good friend after what your you say have to go to the folder blocks and to publish visit_counter_block. tpl and to put where says + 1 to put it in + 0 because if does not count 2 visits instead of 1
The time now is Sat 19 Apr, 2025 07:52 • All times are UTC + 1 Hour [DST enabled]
