Post Style DarkIcy For IP2.0
one more
 nhhhhh
Demo: http://icyphoenix.eu.pn/style.php
prewiev
YouTube Link
http://www.youtube.com/user/IcyPhoenixx
Border radius , Gradient and RGBA supported only by
 browser_compatibility
darkicy.zip
Description: style darkicy for ip2.0
Filename: darkicy.zip
Filesize: 898.37 KB
Downloaded: 421 Time(s)
Edited by Limun, Tue 12 Feb, 2013 11:28: added link demo
Post Re: Style DarkIcy For IP2.0
I was listening to the music - Could you show me that theme again?
0064
The stream wasn't all that good this morning, so I really couldn't get a clear view of the theme.
Off Topic
I love the music too but i started wondering when Candy's clip would begin
YouTube Link
Serious.. I love the presentation Limun
mort wrote: [View Post]
i will put images also..
i dont know why on youtube stream is so low quality
Very nice style and presentation, well done my friend.
to all my styles i added a link demo
The Demo's are not loading with FF, and Mate, there are so many errors , warnings, double-DOC types and missing javascript that it's difficult to tell where and what is stopping anything from loading properly.
I also note a lot of css errors - such as background-color: none? just to mention one.
Yeah! I could say that they are GREAT - But that doesn't help you in any way whatsoever.
You should try to validate the themes html and css you make with WC3 and end up with a better product.
No offence, but I read this at 1000 words a long time ago - - - One is better off spending the time to create one GREAT PICTURE that is fantastic - Rather than spend their time passing in a heap of crappy ones that are mediocre.
I know you are working hard at what you are doing, but I also know that you can do better.
yeah i know about errors and i will try to "clean" them in future
missing javascrpt shoud be only in style.php because i didnt fixed that yet
also i use progid:DXImageTransform.Microsoft.gradient and i dont know why that is an errors
and of course some errors i dont understand
the site is on free server just for show my styles and some testings for now
i open site with FF ,i dont know why you cant
thanks mort
I'll spend some time going through some of the things that possibly needs to be changed with you, but at the moment I'm up to my eyeballs with other things that have more priority.
But if you are going to use stuff for css3 and IE9 then you would need to add the variations between the head tags.
Remember this sort of stuff - - Not an IP example - -  but unfortunately it hasn't gone away!
So if you are going to use browser specific mark-up particularly for IE, you need to add the css that is not compliant with WC3 in statements in between the header tags.
Edit:
Free servers are not worth the crap they are not written on - - Talk to MG - - See if he has any suggestions that may help you get a "Better" result.
Edit - Edit:
On the other hand Limun, If you are still running your "Old" site, you should be able to pick up another Domain Name and add it to your existing ISP as a totally independent domain that has no connection with the parent domain.
Great work Limun, I like it.
