Re: Style Rijeka For IP 2.0
And the pink decoration looks nice, but I'm not sure if I like the pink buttons.
What about the buttons being the same colour as the category headers?
Edit:
Also I would download it and use it for a while but I don't have WINRAR installed. And the last time I downloaded and went to install WINRAR it came with so much crap that even if one checked the
"Don't Install This or that" it installed the crap anyway - which was difficult to remove, so I got rid of the lot of it.
And as ZIP is mostly integrated by default, you may want to consider using that instead.
