Post Rename All The Prefix For Tables In Database: ???
Hi does anybody know if its possible to rename all the Prefix for tables in database: from Phpbb_ to ip_ at once or do they have to be done individually Example, Phpbb_categories To Ip_categories etc. ?
batmanSend private message
Post Re: SQL For Changing Example, Phpbb_categories To Ip_categories
You need to use phpMyAdmin to rename the database and then rename the tables or vice versa.
The other option is to dump the Db in an editor and do a search (phpbb_) and replace (ip_)
Post Re: Rename All The Prefix For Tables In Database: ???
Hi sorry Mort just edited my post
phpMyAdmin will rename all the table prefixes in one go.
select all -> with selected -> rename prefix.
Popup -> from -> to
GO!
thank Mort i just replaced all in notepad, thanks
That is the easiest way and is generally what everyone does.
Post Re: [SOLVED] Rename All The Prefix For Tables In Database: ???
I'm new user and I used icy phoenix 1.3 before and HP0-J67 braindumps - testking
 I pass icy phoenix 2.0 and want to install the mod shop forum but I asked to modify files that are not as "includes/page_header.php" and would like to know this where it is located but nothing.
runtoo75Send private message
Hello,
to have a mod adapted, please ask in a new topic, in the "MODs Discussions" forum.
