Artie
FAP CUSTOMIZATION - Remove OTF
JustTwistedd wrote: I recently added FAP into my PHPBB2 Forum.
Where can I edit the Album so there is no OTF Gallery at all?
Artie wrote: To remove the OTF link you can edit the template file album_box.tpl
#1 Mon 08 Jan, 2007 22:18 |
buldo
Re: Remove OTF
OTF is a great feature of FAP who wants remove it?
Thanks, Artie.
Ciao,
____________ ~~~ Andrea ~~~
User #379756 on Linux Counter
#2 Mon 08 Jan, 2007 22:29 |
Artie
Re: Remove OTF
Thanks, Artie.
Ciao,
I agree, but it's also provides simple way to hide from users.... if you so wish.
#3 Mon 08 Jan, 2007 22:55 |
Re: Remove OTF
Thanks Artie,
I think it would helpful for some people.
#4 Mon 08 Jan, 2007 23:51 |
lefty74
Re: Remove OTF
You could also just make it visible for admins only. that way you still have the OTF possibility but it is not visible.
#5 Tue 09 Jan, 2007 00:41 |
Re: Remove OTF
I'll try to add some permission level access when I have some free time.
#6 Tue 09 Jan, 2007 22:04 |
Artie
Re: Remove OTF
Mighty Gorgon and free time
Now that's an Oxymoron if I ever heard one.
#7 Tue 09 Jan, 2007 22:10 |
Re: Remove OTF
He he he... I'll do it sooner or later... trust me...
#8 Tue 09 Jan, 2007 22:12 |
krisbfunk
Re: Remove OTF
hehe, i didn't see a need for this aside from those with ftp access, which is only admins on my board, so all i did to remove this was remove the code from the tpl file, and added a link to it in the admin panel. not as good as a permissions change, but it works.
i also set the attachment mod to upload directly to a specified directory in the otf folder, so unconstrained images uploaded with the attachment mod can be viewed via the admin panel otf link.
#9 Fri 12 Jan, 2007 08:38 |
Frost
Re: Remove OTF
Microsoft Works.... <- biggest oxymoron of all...
#10 Fri 12 Jan, 2007 09:04 |
KugeLSichA
Re: Remove OTF
Frost you are sooooooo right
#11 Fri 12 Jan, 2007 09:41 |
Matt_UK
Removal Of OTF
Howdy guys
OK I run a motorbike forum and have installed the FAP.
I dont really have a use for OTF so is there any way of me removing this option from the FAP, as theres no point in clicking it if it wont be used and its confusing as people will wonder what its there for.
Cheers guys.
Matt
#12 Wed 24 Jan, 2007 12:41 |
lefty74
Re: Removal Of OTF
Do you want to get rid of it completely or just viewable for admins?
The simplest way of removing it from view but leaving its features in place (in case you change your mind at some stage) is as far as I can tell by going to templates/subSilver and removing these lines
- <tr>
- <td class="row1" height="50" colspan="{catfooter.cat_public_footer.FOOTER_COL_SPAN}" onMouseOver="this.className='row2';" onMouseOut="this.className='row1';">
- <span class="forumlink">
- {NAV_DOT} <a href="{U_ALBUM_OTF}" class="cattitle">{L_ALBUM_OTF}</a>
- </span>
- </td>
- </tr>
#13 Wed 24 Jan, 2007 19:02 |
Artie
Re: Remove OTF
Name of template file to modify at top of this thread.
Topic moved to Customizations forum and merged with similar.
#14 Wed 24 Jan, 2007 23:30 |
Shaythong
Re: Remove OTF
Is it OK, if I do it this way? So I can get a backup If I want:
- <!--<tr>-->
- <!--<td class="row1" height="50" colspan="{catfooter.cat_public_footer.FOOTER_COL_SPAN}" onMouseOver="this.className='row2';" onMouseOut="this.className='row1';">-->
- <!--<span class="forumlink">-->
- <!-- {NAV_DOT} <a href="{U_ALBUM_OTF}" class="cattitle">{L_ALBUM_OTF}</a>-->
- <!--</span>-->
- <!--</td>-->
- <!--</tr>-->
That's OK right? I'm using the Icy Phoenix 1.0.66 I guess. The code is a little different here, but that code above is just in the normal one. With the "<!--code-->" to disable it instead of showing it.
I mean some people don't really need OTF's features and just want an album. They should add a "On-Off" option for OTF on and off for album in Icy Phoenix.
#15 Thu 08 Feb, 2007 03:08 |
