Post Updating Rainbow Pearl To 3.0.8
Well folks,I'm been getting pounded by spammers and I'm trying to get Q&a to work on my site.
The Q&A question does not show on the registration page.
(Style updated problem) Works fine with the default prosilver/subsilver2
I have downloaded the current rainbow pearl 3.0.8
The problem i have i have a ton of mods on my site and there is no way i could go through ALL the edits to make this work.
I have winmerge and have tried to make it work. No luck!!
IMO: There has to be one or more edits to make this Q&A show on my site without going through a ton of styles edits.
Please i need some help with this before i get over run by these spamers from around the world.
NuworldSend private message
Post Re: Updating Rainbow Pearl To 3.0.8
Nuworld wrote: [View Post]
Why bother with WinMerge?
I don't use phpbb and am possibly out of my depth - But the code fixes for phpBB templates are posted here!
http://www.phpbb.com/community/viewtopic.php?f=74&t=880735
And I don't think that MG varies the default code that much!
Then why don't you uninstall Rainbow Pearl and use the default theme until you sort this problem out!
this is what should be in captcha_qa.html
        <th colspan="2" valign="middle">{L_CONFIRM_QUESTION}</th>
        <td class="row1"><b class="genmed">{QA_CONFIRM_QUESTION}:</b><br /><span class="gensmall">{L_CONFIRM_QUESTION_EXPLAIN}</span></td>
        <td class="row2"><input class="post" type="text" name="qa_answer" size="80" /></td>
        <input type="hidden" name="qa_confirm_id" id="confirm_id" value="{QA_CONFIRM_ID}" /></td>
and this should be the part that is replaced by a question:
can you check if that is the same?
______________
EDIT:
@ Mort..
That is for prosilver
