Post Black Pearl Diff Or Patch File From 3.0.5 To 3.0.6
Hello MG, i had a problem in my black pearl skin when my board is on version 3.0.6, i cant voting in the polling section, and when you release the Black Pearl style for 3.0.6, the problem's gone but all of my MOD is disappear... so how can i prevent that? do you have black pearl diff or patch file from 3.0.5 to 3.0.6 ? Thx u!
Noctis88Send private message
Post Re: Black Pearl Diff Or Patch File From 3.0.5 To 3.0.6
Unfortunately no code changes.
You may try to follow subSilver code changes to see if you are able to upgrade without messing up things.
Otherwise you should try using WinMerge.
