Hello, I write this, because in my forum in the downloads section, when I apply the permissions for users, note that no permission does not apply since the ACP / downloads / licenses. you can be?
I've done everything, clear cache, installing everything again ... if I want to apply permissions does not work overall. but if I do like the images below if it works.
If the category already created ... select Edit Categories.
Press "Ok" and gives us the option to edit permissions.
ponemos los permisos
and here we confirm that the permissions are updated. EXCEPT global if we do not I get this last image.
This is an immediate solution, it does not work if we are to broadly permits would be interesting to revise.
The time now is Wed 23 Apr, 2025 09:01 • All times are UTC + 1 Hour [DST enabled]
