Post Custom Profile Fields Problem
Hello Everybody..
I have a problem with the Custom Profile Fields... I'm trying to add one, and it tells me that the new field was added successfully, but later, when i try to edit it, i can't, because there are no custom fields added. And, if i try to add the Custom field again, i can't, because the page tells me that it already exists.....
Any solution??
Thanks!
DanielcSend private messageVisit poster's website
Post Re: Custom Profile Fields Problem
Try clearing your cache.
Thanks!! It solved the problem!
