Post [MOD IPv1.3.0.*] Active Members Url Only
Title:
   Only Active Members Can Post URLs
   Members must be registered for at least X days and have more than Y posts (configurable in the ACP) before they can post URLs.
Download the Latest Version Here!
Other helpful Documentation - "How to add the SQL for the MOD using Icy Phoenix"
Additional Language Files
MOD Updated 26th August 2009 - 08:00pm.
Edited by Guest, Sat 15 Aug, 2009 00:46: Added Language Files Link
Edited by Guest, Wed 26 Aug, 2009 12:57: MOD Updated 26th August 2009 - 08:00pm.
Edited by Guest, Fri 28 Aug, 2009 00:38: Changed Download Link
Post Re: [MOD IPv1.3.0.*] Active Members Url Only
This is nice... what about extending it by also allowing signature showing up after the same period of time?
Another MOD author is on fire!
Great stuff!
I think you will find it looks at all code-boxes (Editors) when the submit button is hit. So the function to block url's in Sig's should already be in place.
I will check it to understand how it works and see if also allows what I need.
