Re: Adding A Link To The Sidebar Main Links (1.2.0.27c)
What!
The dynamic menu is one of the best things about Icy Phoenix! All you need to do is switch the block file wherever you see the outdated
nav links [Site Map] block. You no longer need to edit a file to add/edit/remove links. You can add/edit/remove links via the CMS now.
Glad you got it fixed
Pyro-Tech!
The thing about it was the Block Menu ID number (default = 0) didn't like the default. I was messing for like 10 minutes with other options and finally changed that to 1 and it worked fine.
Don't get me wrong, i love the dynamic menu....now if there was a way to make custom pages within IP, then i would be set now!
but again, thanks for the help.
EDIT: nevermind....i think i see it on the first link you gave....so yay....:D
